Wow, sounds like you guys have answered most of the questions for me.
Regarding Ste2's question:
This kit is a benefit to any car that has been lowered at least an inch, regardless of if that be by coilovers, struts/springs, or any other suspension mods.
Without going too technical, lowering has a negative effect on the suspension geometry, which this kit fixes and improves on.
jimGTS:
As mentioned above, basically if your car is lowered the kit will help, other mods don't really add or detract from it's effectiveness.
Regarding geometry setup, the intent is that there is some additional adjustment available, but that it
*shouldn't* be needed for most people.
I have tried to pre-set everything to be as close to optimal as possible.
Beyond that, the main thing that is needed is just a good alignment.
Regarding bump steer, it's actually not too hard to build a simple bump steer gauge and check it yourself.
mr2oc.com/showthread.php?t=455693
mr2oc.com/showthread.php?t=452807
However, for most people, installing per the instructions and getting an alignment should be enough.
Track only?
Technically that is what I recommend it for, but that is mostly a liability thing
(sort of standard aftermarket parts disclaimer).
In terms of benefits, it will benefit handling anywhere, but it is really intended for cars that will be pushed to the limit on the track.
Race Idiot:
There are products available to protect rod ends
(rose joints).
Some are of a full boot design, some are a more simplified face seal.
I have experimented with them a little, but wasn't impressed, at least not with the ones I tried.
The boots are quite difficult to install, and don't seem to hold up too well either.
The face seals are easy to use, but it's hard to say how effective they really are.
They wouldn't work on the front either.
Unfortunately, for a street car the added maintenance of looking after rod ends is the biggest downside to this kit.
