how did I not know about this engine when I owned a tubby
and why was it put in a family wagon lol
how does it compare to a gen 2 3sgte or a rev5 mr2 tubby tuning wise
any info appreciated
Race Idiot wrote:Also apparently the rev3 exhaust mani can be used instead of the integrated turbo manifold.
Peter Gidden - SBITS wrote:
If you change the turbo too.
http://www.sbits.net/pics/gen4_turbo.jpg
vtecpower wrote:
And being newer technology surely the individual coils must be better than dizzy cap rotor arm
vtecpower wrote:It would be interesting to hear from someone in the uk that owns one
Apparently spool time is faster!
I think I read that the internals are slight different I wonder if that's for better or worse,(can the stock motor handle more than the stock rev5 tubby)?
jimGTS wrote:vtecpower wrote:It would be interesting to hear from someone in the uk that owns one
it spools quicker as it has a slightly smaller turbo
sure, coils newer tech, also at£100+ a pop to replace, are more expensive than a set of leads by a long way when its time to replace.
Unless you are talking about silly power levels, oem ignition setup is fine
i see the appeal with the sidefeed inlet manifold, which i hear is good.
all in all, i only see the appeal of one if looking at silly 600+hp power levels.as youll be taking advantage of ignition, sidefeed and thick block, other than that, seems more hassle than its worth on a BPU mr2.
sure the oem turbo on there spools very fast, but it also wont make the power a ct20b will.
swings and roundabouts.
the guy on the OC has hooked up an awesome engine monitoring program to it though, as its OBDII i think its called!
sinjen wrote:Rods are the same as the beams, so lighter and less bulky at first glance than the gen 3, this aids engine response.Usual unsubstantiated gossip about them being weaker but nobody knows what they're actually made of, forged or otherwise, so whether they are weaker or not, nobody actually knows.
Besides over the seas there a few on standard internals running circa 400bhp.
It bolts straight up to the S54 and E153.
Makes more power than the gen 3(even with a smaller turbo), around the 260-270 mark.
Fuel cut is 19psi, actuator is 8psi and standard boost is 11.7psi.
Afaik the ecu still isn't mappable, but it is obd2
Getting hold of a manual ecu is difficult as they mostly came with the auto 4wd box, but the auto ecu runs perfectly once you have put the NSW to ground.
