[Mk2] [NA] rusty / seized bolts Mk2
smashing666
Post by smashing666 »
Hi All,
I'm going to embark on some restoration work and will be stripping the car slowly. I've had a quick go at loosening things like the caliper and handbrake related bolts and had no real luck, so I imagine getting to wishbone bolts would be even harder. What would be the best method for loosening rusty / seized bolts, WD40? Blow torch? Freeze spray?
Cheers!
Julian
thomp1983
Re: [Mk2] [NA] rusty / seized bolts Mk2
Post by thomp1983 »
plus gas, a decent set of 6 sided sockets and a decent quality breaker bar is about all you should need for most bolts on a '2
KarlBristol
Post by KarlBristol »
thomp1983 wrote:plus gas, a decent set of 6 sided sockets and a decent quality breaker bar is about all you should need for most bolts on a '2
+1
Although for the suspension bolts I found the best method was a blow torch and a bloody big breaker bar as some of those bolts are rather large and very seized :lol:
For the undertray bolts you will snap pretty much all of them so expect to be drilling them out :thumleft:
smashing666
Actually managed to shear a floor bolt today!
Any advice on hand held torches? Where and what type of gas?
thomp1983
Post by thomp1983 »
gas i use,
http://www.screwfix.com/p/rothenberger- ... 277g/85021
i use it with a cheap screw on torch but screwfix seem to have stopped listing them b&q might have them
chris
aliendoughnut
Post by aliendoughnut »
plus gas
