After taking Pauls advice above, I postponed buying any new parts until I'd got the head off which I did last night.
It immediately worried me that I couldn't see any blow past the head gasket although on a brighter note, the block around all the cylinders and water jacket is in excellent condition with no corrosion which I gather is unusual in these engines as they age.
Today I've stripped the head, taking out and bagging the valves etc.
and then gave it a good clean up.
I was still worried about the lack of a blow across the gasket.
on most other head gaskets I've changed on other cars, the blow is usually apparent and this made me think that the head may be cracked.
After cleaning it up, I think I can see a faint line from n0.4
to the water jacket in the head but my eyes aren't getting any younger and I might be seeing things.
I suppose a pressure test is the only way to know for sure.
My question is:
do I get this head pressure tested tomorrow or just buy a second hand head.
If I get mine tested for
£40 but it is cracked then I still have to buy a second hand head.
there again, if it tests ok, I've saved the expense and hassle of buying another head.
what should I do?
Also, what's the going rate for a second hand head?
I already know that my own foolish actions have led me to this point but any advice on what to do about the cylinder head would be welcome!
thanks,
Ian
