missing pipe!!
g3m uk
missing pipe!!
Post by g3m uk »
we have a missing pipe on the top of our engine and we cant quite figure out where it is ment to go to or what it is for!!
we have a dodgy idol, could this be the problem?
I have a picture but cant upload it as don't have enough posts!! :(
I hope someone can help us! x
g3m uk
Re: missing pipe!!
Post by g3m uk »
g3m uk
Re: missing pipe!!
Post by g3m uk »
You can see in the pic that one of the vacuum pipes on throttlr body is missing you can feel and hear it hissing....
Anyone know where it runs ?
kaiowas
Re: missing pipe!!
Post by kaiowas »
I've not got an na engine to look at for reference but I'm pretty sure that the pipe going to the outlet next to that should be on there. At the moment it looks like the pipe has been attached to a blanking cap (the darker black short section of pipe - you'll probably find the end of it is closed off if you take the hose off it)
SuperRedMR2
Re: missing pipe!!
Post by SuperRedMR2 »
I've always had that blanked off...
g3m uk
Re: missing pipe!!
Post by g3m uk »
SuperRedMR2 wrote:I've always had that blanked off...
Just with like a little rubber bung thing?
un1eash
Re: missing pipe!!
Post by un1eash »
The tube should be connected to the right pipe and the left pipe should have a blanking plug on it.
jimi
Re: missing pipe!!
Post by jimi »
un1eash wrote:The tube should be connected to the right pipe and the left pipe should have a blanking plug on it.
g3m uk
Re: missing pipe!!
Post by g3m uk »
Thanks guy. Swapped that round this morning, as like you say the other one has a suction on it, it lasted longer before the idol started searching so still need to keep thinking of what else it could be! Thanks for all the advice xx
kevs aw11
Re: missing pipe!!
Post by kevs aw11 »
Hi
if your revs are surging and your rev counter is bouncing there is air in your system it needs bleeding
hope this helps
kev
PW@Woodsport
Re: missing pipe!!
Post by PW@Woodsport »
Or the AAV is stuck.
