Rev 3 or 4 ?
Rev 3 or 4 ?
I've got a P Reg UK NA car.
How do I tell which Revision it is?
Re: Rev 3 or 4 ?
I believe the Rev 4 onwards got the standard Toyota clear indicators but maybe wrong?
The only thing I know of is that some Rev 4's were 2 tone although I don't know how many colours were in the range etc
Re: Rev 3 or 4 ?
Re: Rev 3 or 4 ?
P
-reg is almost certainly rev4
Re: Rev 3 or 4 ?
My old car was a P reg NA and it was a rev3, had amber and clear front indicators, no airbag wheel, no egr etc.
Seatbelts said 1996 iirc though.
Re: Rev 3 or 4 ?
That's a good point.
If it's a Rev 4 it'll have an EGR valve
Re: Rev 3 or 4 ?
MR2 MK2 Chassis Numbers
Chassis numbers;
Revision 1
- December 1989 to December 1991
Chassis JT163SW2000000001 to JT163SW2000059265
Revision 2
- December 1991 to November 1993
Chassis JT163SW2000059266 to JT163SW2000087385
Revision 3
- November 1993 to June 1996
Chassis JT163SW2000087386 to JT163SW2000106662
Revision 4
- June 1996 to December 1997
Chassis JT163SW2000106663 to JT163SW2000110780
(Approx)
Revision 5
- December 1997 to August 1999
Chassis JT163SW2000110780
(Approx)
Chassis numbers;
Revision 1
Revision 2
Revision 3
Revision 4
Revision 5
No 2
Re: Rev 3 or 4 ?
Ryan6926 wrote:That's a good point.If it's a Rev 4 it'll have an EGR valve
If it's a UK rev4, yes.
If it's a JDM rev4, no.
Re: Rev 3 or 4 ?
Thanks.
does certanily have the high level brake light so Rev 4 it is
Re: Rev 3 or 4 ?
The only way to 100% confirm it is to check your chassis number.
Anything physically on your car now could have been changed after it left the factory.
No 2
Re: Rev 3 or 4 ?
MR2 Rich wrote:The only way to 100% confirm it is to check your chassis number..
Re: Rev 3 or 4 ?
Chassis no.
checked
- thanks for the tip.
rev 4
Re: Rev 3 or 4 ?
RikH77 wrote:3rd brake light from rev4 on
As said on a P its rev4
sorry m8, but my rev 3 n/a had a 3rd brake light, so does my rev 3 tubby
Re: Rev 3 or 4 ?
I thought the third brake light was an import feature?
Re: Rev 3 or 4 ?
I believe it was but if it's the same as the Gen 6 Celica idea then when they facelifted then in approx 96 they added the 3rd brakelight so I'm guessing iit's probably the same as the Mr2 only Rev 3 became Rev 4 which would be when they added the EGR valve etc?
Re: Rev 3 or 4 ?
sean1881 wrote:RikH77 wrote:3rd brake light from rev4 on
imports only
Re: Rev 3 or 4 ?
RikH77 wrote:sean1881 wrote:RikH77 wrote:3rd brake light from rev4 on
imports only
that may be the case m8, but it had 1
Re: Rev 3 or 4 ?
UK cars had third brake lights too.
But IFAIK, the imports got them earlier
(I think UK cars didn't get them until rev4).
Re: Rev 3 or 4 ?
JohnnyC wrote:UK cars had third brake lights too.
But IFAIK, the imports got them earlier(I think UK cars didn't get them until rev4).
my old 1 was a uk 96 P registration rev3 with 3 brake lights.
