hi,
i have build big 3sgte for my mr2 and i have 2 problem.
the first: i can remove completly the VSV because i have boost controller ?
the seconde: i have put big Mustang TB and i can put the iac on this.
how remove the iac? or modifier mustang TB for put this?
please help me
picture of my engine:
my TB
The old IAC
[Mk2] [Turbo] Mustan TB for Big 3sgte
Re: [Mk2] [Turbo] Mustan TB for Big 3sgte
My ICV is welded into my inlet manifold itself- just an idea, but it does mean you don't need to find a way to add it to your TB
Poor picture, but you can just about see it here:
Looks like an interesting engine you've got there- what turbo is that? Lots of RacerX parts
HI,
have you an other picture please? because i see nothing.
Yes the turbo kit and intake manifold is racer X.
The turbo for start is Precision PT5858 and i think that if i would like more power i will go with PT6262.
I see what you explain me!
many thanks for you response.
you have take only one hose who go to the intake pipe it's that?
and the 2 coolant hose i can remove this?
The hose goes to the inlet after the air filter so that only filtered air is let into the inlet manifold on idle.
The two coolant hoses are not connected- they are used to run engine coolant through the valve to warm it up, I have never had them connected and it has not been a problem
I'm happy by your response! many thanks!
and the VSV i can remove this completly (i have a boost controller)?
Yes you can, but after that your boost meter on your speedo doesn't work any more. Was useless anyway
