So I have a problem with my handbrake, one side works the other doesn't.
Got under the car removed both wheels and under trays
I then did the well documented process: slacked cable
/ wind in piston
/wind out piston 180 degrees
/ re-assemble
/ pump brakes
/ adjust cables.
still nothing on the passenger side.
Now,
both cables move freely and you can operate both levers by hand which both return to the stops.
BUT one side cable
(Non working side) has about 20mm cable travel and the other around 60mm.
this is also replicated on the balance bar by it leaning quite a lot to one side cable.
Anyone think i could have a wrong cable fitted to the nearside of the car
or should i be looking elsewhere to solve the problem
I don't want to go buying new calipers and cables if I'm missing something else with it.
