Constantly getting crazy readings,
I've earthed all the connections together on the chassis, and even run an earth cable directly to the battery at the same point.
Pretty sure all the wires are correct way around.
So best place to mount the pressure sensor? Have mine going from the inlet chamber to the charcoal canister at the moment.
Could i have boost leakage somewhere? Causing dodgy readings?
