[Mk2] [NA] Non starter
jonnychapp
Post by jonnychapp »
Any one help :?
Got 91 mr2
I've changed plugs dizzy cap rota arm plug leads and coil pack and checked fuses but won't start anyone help?
jasongtr
Re: [Mk2] [NA] Non starter
Post by jasongtr »
a bit more info maybe, when was it last started? did it break down?
jonnychapp
It was kangarooin so revved it a bit to get it home then drove home ok but didn't start next morning??
jasongtr
Post by jasongtr »
fuel issue perhaps?
blocked injectors, failing pump?
jonnychapp
Yeah was thinking fuel pump ill have a look at that I think thanks
jasongtr
Post by jasongtr »
undertrays off and drop the fuel tank for that lovely job
jon
Post by jon »
The amount of fuel required to start the car is tiny, even if the fuel pump was on it's way out it should still start the car.
Crank the car for a few seconds and then pull the plugs, if they're dry then the pump is not working at all, if they're wet then there is enough fuel to start the car and the problem lies else where.
