I had a new
Has anybody else had the problem or know a simple remedy as it will certainly annoy me after a while.
Cheers all
Rob
ashley wrote:I had the same issue with the NA exhaust, it's just the way they make them![]()
You can adjust a lot of it on the hangers as the slots the bolts go through are larger than the bolts, to get the rest of it you could ubbolt the hanger from the chassis on the side that is sitting higher and put an ali spacer between it and the chassis to lower it..
RikH77 wrote:they do offer rolled in na, i have one on my black rev5
You can adjust a lot of it on the hangers as the slots the bolts go through are larger than the bolts, to get the rest of it you could unbolt the hanger from the chassis on the side that is sitting higher and put an ali spacer between it and the chassis to lower it..
K22WES wrote:you should be able to adjust that on the rear hangers, loosen the bolts and push up or down to get it fitting level.i have even bent the brackets in or out to get them sticking out level on the 3 i have fitted.
