[Mk2] [Turbo] boost leak?
got a mk2 rev2 mr2 that keeps juddering at approx 2500rpm can hear air being sucked into the turbo but no boost the car also has a rough idle sometimes stalling if i put my foot down will backfire at 3000rpm any help
Re: [Mk2] [Turbo] boost leak?
Have you changed anything recently?
Is your boost gauge showing normal boost pressure? if so doubt it`s a boost leak causing the problem.
Possible AFM fault?
Ignition timing?
Possible AFM fault?
Ignition timing?
thank you its driving me mad at the moment as carnt figure it out
not had the car long was running great then this happend nothing was changed
If it's suddenly just stopped making positive boost pressure I'd start by checking if there are any IC or vacuum hoses that are loose or popped off.
found a split in a pipe today so just waiting for a replacement fingers crossed its the only 1 as couldnt see anymore
right replaced the pipe and low and behold it hasnt worked
It could be the knock censer, That would make it judder at 2500rpm.
But you would see the engine warning light come on.
have found the green sensor by turbo belive its called e.c.u temp sensor that has destroyed its self new one orderd and arrives thursday
