I am after a map to get the engine running and make things easy for me
bobhatton wrote:Is anyone using the Link G3/4 on a Rev3 with stock sized injectors?
sheppy wrote:bobhatton wrote:Is anyone using the Link G3/4 on a Rev3 with stock sized injectors?
i believe turbonoz is running a G3 with stock injectors Bob.![]()
bobhatton wrote:sheppy wrote:bobhatton wrote:Is anyone using the Link G3/4 on a Rev3 with stock sized injectors?
Rev2 I think, but would not want to try any map he may have set up
bobhatton wrote:but would not want to try any map he may have set up
sheppy wrote:bobhatton wrote:but would not want to try any map he may have set up
meow!!!![]()
mr2c8cya wrote:hi i have a map for a g3 which will get your car goin,
Kim Jong un wrote:I thought you only used motec![]()
"the best" bob?
bobhatton wrote:Kim Jong un wrote:I thought you only used motec![]()
"the best" bob?
I am glad you are keeping up.
Its a friends car, he had the ECU fitted by Thor a number of years ago and it never worked, in fact it damaged 2 engines.
I have sent it back to Link to be checked out and they found someone had been soldering parts on the board, this has been repaired and now I need a map to start afresh from.
On my cars and my sons it will only be"the best"
bobhatton wrote:Rev2 I think, but would not want to try any map he may have set up
