[Mk2] [NA] Clutch Bleeding
westymr2
Post by westymr2 »
Hi,
The clutch on my new MR2 is slipping and has a extremely high biting point.
My thoughts are to bleed the system and try adjusting the pedal as the clutch has been replaced in the last few thousand miles.
Has anyone got any tips for bleeding the clutch?
Josh
bobhatton
Re: [Mk2] [NA] Clutch Bleeding
Post by bobhatton »
westymr2 wrote:Hi,
Josh
It does not sound like it needs bleeding at all.
Adjust the pedal so you have the correct amount of free play and see if it still slips, I am sure it will as it has been before and will need replacing again
westymr2
Post by westymr2 »
bobhatton wrote:
Peter Gidden - SBITS wrote:
westymr2 wrote:Hi,
Josh
Bleed as you would a brake caliper.
Thanks yeh I think I'm in denial about it needing a clutch. I don't really fancy changing it... so I'm going to try every other possibility first!
Any tips on bleeding it anyway... The fluid is due a change as is unknown age and been sat for at least a couple of years
Cheers,
Josh
hmltnangel
Post by hmltnangel »
for bleeding the clutch - you want this ........
http://www.ebay.co.uk/itm/271001723850? ... 1497.l2649
