I think I'm kind of doing this the wrong way round as the car is pretty much done now.
I suppose I can use this to update how long the engine lasts
& how well the car does on the drag strip.
I Bought this car as a temporary runaround in April 2011 for minimal outlay whilst my 523bhp 4dr R32 GTR was off the road.
It had a broken stainless manifold and was very slow and very noisy.
It also had holes in the sills and faded paintwork, but at least it came with a huge folder full of paperwork.
Also came with a Genuine Autopista spoiler, TSW Evo alloys, turbo timer
& electronic boost controller.
First thing was to try and weld the manifold back together.
This generally worked well for about 1 week at a time.
As with all my modified cars, I fitted a set of my favourite spark plugs: The inimitable NGK BCR8ES.
As I have had numerous high performance cars over the years, I have a large number of various goodies lying around, one of which was a Pulsar GTiR IC converted for use with a Rover 220 Turbo Coupe.
This worked well as a top-mount IC on the MR2, response of the car was brilliant:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0030.jpg)
Random shot of MR2 on TSW Evos with various black panels at Santa Pod:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/CC2644_zps02ee972a.jpg)
At this point I decided to fit a stock log manifold and also ruin everything I liked about the car
(its drivability) by fitting a huge intercooler in the boot with 3 piping.
The intercooler is from my old 400+bhp S13, originally being a prototype designed for the Norris Designs 600+bhp S13.
Yup, one off 700bhp-spec intercooler in the boot of a tired MR2 still fitted with a tiny CT26.
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/BMIC-crop_zpsf4de4f86.jpg)
Profec B Spec2 from my terminally-goosed R32 fitted.
Boost was increased to 1.4-1.5 bar on the stock turbo, still running the stock ECU, 440cc injectors, restrictive fuel rail
& fuel pump.
Base timing was reduced to 8° BTDC to keep knock at bay, but things started running a bit lean at anything past 1.2 bar one day.
Time for a fuel pump upgrade! I didnt have any uprated pumps lying around, so had to dig deep and bought a 255lph jobbie from eBay.
The thought of removing a fuel tank in order to swap a fuel pump goes against everything I know.
Sometimes manufacturers just get things wrong.
Cue a Fuel Pump Access Panel Modification
(patent pending):
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/FuelPumpAccessPanel_zps1413024e.jpg)
Job done, AFR was a solid 11.5:1 at 1.4 bar on the stock ECU, injectors
& rail.
At this point, there was nothing more to be done but fit an aftermarket ECU.
Power FCs are old school
& over-priced for the 3SGTE, so I went for a 2nd hand Link G3 that had previously been hard-wired in an MR2 turbo.
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0051_zps39fbb4f5.jpg)
After trying to source a patch cable and getting stupid quotes, I made one myself using a gutted NA ECU for the plugs.
The G3 is a joy to work with and I soon had the boost increased to 1.5 bar with intake temps at a nice safe level thanks to the BMIC.
I was getting a bit worried about the ability of the stock fuel rail, so when a set of Delphi 85lb injectors
& Wolfkatz top feed rail turned up for sale, I couldn't say no.
Especially for
£150 all in.
The seller also had a set of forged Wossner pistons, a modified TVIS plate
& ported/polished intake runners, so snapped all these up at the same time, just in case.
In went the injectors, rail and an adjustable Sard FPR from my old S13
(set at 3 bar base pressure).
Head bolts tightened an extra quarter of a turn as well.
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0058_zps582693ca.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0059_zps3fe8a8d4.jpg)
A set of light Enkei RP01s turned up for sale on SXOC, so these were bought immediately.
They came into the country originally on one of Phil Morrison's cars.
Extra JDM Tyte points for I methinks.
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/LHS_1024_zps2cd240d7.jpg)
So, now time to refine the map on the road and see what we can get out of the much-maligned stock CT26.
This was all going to plan, and the map was pretty much complete when disaster strikes!! On the way back from a small festival in Leeds in Nov 2011, the Hose From Hell decided to let go on the M1.
It's quite surprising how much fun a tiny hole in a tiny pipe can cause:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0061_zps9ce964ee.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0060_zps963068db.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0062_zps0444cb58.jpg)
This dude was suitably impressed:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0063_zpsb3d773ef.jpg)
Saved quite a bit of petrol on the way back to Leicester
The MR2 was relegated to one of my garages whilst I concentrated on selling my boring Soarer TT
& modifying my 300zx TT and Pulsar GTiR.
During this time, I bought various big turbos and put together a kit for a bottom or top-mounted T3 conversion.
I got as far as trial-fitting my Borg Warner S200 when a complete GReddy T78-33D kit came up for sale.
Everything was sold quick-time and this was bought instead.
If you're going to go big, you may as well go BIG.
I had a TD06-20G on my S13 and loved it, so the T78 was a no-brainer.
A trip up to my old hometown of Whitby to meet a fellow IMOCer later and I was the proud owner of this genuine GReddy kit:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0118_zpsd150af88.jpg)
I was a happy chappy.
Even the rents appreciated the awesomeness of low mileage truck turbos that are slightly too big for a stock 2L:
T78 install:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0120_zps2d234eee.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0123_zpsd4a64fb7.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0126_zpsf16b4838.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0127_zps2fd38f34.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0163_zps6c57c5ca.jpg)
All the silicon joiners were lying around, hence the red/blue colour-coding
The car was now ready to start tearing up the drag strip.
It was under strict instructions to do very well else it would get stripped for parts and crushed.
Things went slowly, and it ran a mid 13s.
Quite embarassing, so plenty of mapping on the strip knocked a good second off the time to get it into the mid 12s.
I was limited to 1.5 bar due to the stock G3 map sensor.
The Nitto 555R drag radials hooked up well, and I was running 1.8-1.9 60ft times consistently with launch control.
Video:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/th_TurbonozMR2.jpg)
It wasn't always easy to get to the strip.
A blow-out somewhere near the A6 meant we got to chat cars with another recovery dude:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0166_zps67164d3c.jpg)
Turbo lag was a major issue, the boost controller was maxed out and that would only just allow me to hit 1.5bar at which point the ECU shut down.
Double wastegate springs were fitted and a 7bar repalcement map sensor was sourced and soldered into the ECU.
A side-exit
'exhaust' was fabricated and fitted:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0257_zpsc317d67e.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0256_zps32752526.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0258_zpsb894d8d6.jpg)
Didn't have time to chop it down before the final meet of the season:
![Image](http://img.photobucket.com/albums/v73/bignoz/MR2%20Turbo/IMAG0259_zps84c98904.jpg)
Only managed 1 run at 1.4 bar before rain stopped play
End of season 2012 and out of time!
Fast forward to present time.
Finally get chance to get it on the dyno and see what it can do in a nice safe environment.
At 1.4 bar, it ran 330bhp
& 270ish lb·ft.
About right, given the fact that the turbo barely had time to spool before the rev limit.
After increasing the boost in stages to 2.2 bar, final figures of 487.3bhp
@ 364.6lb·ft were achieved on Shell Optimax
![Image](http://img.photobucket.com/albums/v73/bignoz/Mapping/DSCF6057_b_zps2482acfe.jpg)
![Image](http://img.photobucket.com/albums/v73/bignoz/Mapping/DSCF6056_b_zpse6a3f794.jpg)
My MR2
& a customer's 300zx with 430bhp
& 440lbft.
![Image](http://img.photobucket.com/albums/v73/bignoz/Mapping/MR2Z32_zps1c960d45.jpg)
