Hello,
I know there's lots of stuff about this stuff but I wanted to get it in an easy read format.
Going to look at a tubby.
Just wanted to check the main things that mean I should walk away
(trying not to be swayed by heart on these things is quite difficult
Head gasket failiure
- identified by mayo like residue under oil cap?
is there any other way to identify this?
bottom ends
- I've seen this mentioned a lot but don't really know what it is and how to check
rear sills
- physical check for rust
off colour/wonky panels
- potential signs of repair
Essentially the top three I understand are the main walk away signs.
Is that correct?
Also
- am I right in saying that there isn't much you can do to verify mileage if there is no Japanese history
(other than the MOT service intervals from it's UK life)?
I know one of the
'strut has slight play in the sliding bush or gland
(2.5.B.1b)' as an advisory
- nothing to worry about i hope?
Cheers!
