[Mk2] [Turbo] Cold start pipe????
Nellie966
Post by Nellie966 »
Hi guys and gals, just re-building my engine after a head gasket replacement and i cant figure out where to put this pipe......
I think its the cold start pipe... comes out of the top of the fuel rail about half way across, its about 3 inches long and has a 90d turn in it. its some sort of fuel line think as it has the o shape connecter at the end with a hole in it to allow flow of some sort.
Does the pipe connect to the sensor that goes in to the intake manifold thats held on by two bolts??? this seems right but when i try and line it up it just does not seem to be quite right.
Please help me to locate where i put it...
Thanks in advance..
djpkins
Re: [Mk2] [Turbo] Cold start pipe????
Post by djpkins »
it attachejfsda; to the cold fsdaatrt injector urweqhich jfsdaoundjfsda like the thing you think ijfsda a fsd#jenjsdfaor...fkn keypadsjfa# fkd
Nellie966
Post by Nellie966 »
LOL What???? i can pick out the odd word....
I have established that it is the cold start injector. does this slide over the sensor that bolts into the intake manifold??
toxo
Post by toxo »
djpkins wrote:it attachejfsda; to the cold fsdaatrt injector urweqhich jfsdaoundjfsda like the thing you think ijfsda a fsd#jenjsdfaor...fkn keypadsjfa# fkd
"It attaches to the cold start injector which sounds like the thing you think is a sensor...fkn keypads fkd"
HTH :thumleft:
djpkins
Post by djpkins »
lol...seems to erratically type lines of letters when I'm around the w,e,a,s keys...normally go back and delete etc but was ina rush this morn...
