Water Elbow Painting
TRINDA1664
Post by TRINDA1664 »
Hello
Please can I have some advise on painting the cast ali water elbow.
I was going to get it powdercoated but my local podercoaters are on shutdown and im looking to get it back on the car tonight.
So i am looking to use aerosols. I am going to lightly shot blast the surfaces that are being painted.
Do i need to use primer? if so grey or acid etch?
Also will i need to use a high temp paint? or will normal aerosol paint be ok?
Dan
JSandW2
Re: Water Elbow Painting
Post by JSandW2 »
Dan, vht paint, make surface dull with sandpaper etc, paint....easy, there's tons of vids on youtube, use google! its your friend :thumleft:
Draven
Post by Draven »
As said above make sure you have thoroughly cleaned the services and give them a good rub down with sand paper before prep is by far the most important thing with spraying anything.
JSandW2
Post by JSandW2 »
[quote="Draven"]As said above make sure you have thoroughly cleaned the services and give them a good rub down with sand paper before prep is by far the most important thing with spraying anything.[/quote]
yeah Draven is spot on there, I should have added that as well making sure it's thoroughly cleaned and degreased, spot on :thumleft:
alanmr2turbo
Post by alanmr2turbo »
you dont need VHT paint for the water elbow. I used ordinary aerosol paint on mine and no problems after a year or so.
