Have a tubby and she has developed an oil leak on the turbo side of engine up the cambelt end.
Oil seems to of soaked pretty much the whole back of engine bar the top right and I have not got a clue as to where its leaking from.
It leaks quite a lot and the amount covers the sump and bottom of engine where when moving the wind blows it towards back of car from under neith.
Today I spent most of the day
Managed to remove exhaust, CAT, cat to engine mount brackets, back engine mount, the turbo heat sheilds etc and with the car up on ramp I can just about poke my head up in where the cat
However I still cannot locate the leak, I initialy thought it was the oil cooler gasket but the oil is comming from higher, however I can see the joint between the cylinder head and engine block and core plugs they are all clean and no oil at that height.
I also took the turbo oil feed pipes off and checked for holes etc but the set is fine, I have not yet taken the air conditioning compressor off
I replaced the cam shaft cover gasket set a while back and used the high temp silicone in the corners as per original and tighteded the bolts to correct torq as 2 of the spark plug holes filled up with oil and I had a leak around the alternator this is known fixed and I have no weaping of oil from the cover at all, the dizzy is not leaking.
The only thing I can think of is possibly the exhaust cam shaft oil seal has gone leaking oil or possibly the top of oil pump gasket, but crank shaft and cam belt covers are clean
It is actually leaking quite bad and I have to top up oil every month as its leaking that much.
If I had another car i think I would drop the whole back end and replace all seals and gaskets and get engine cleaned but having to use it for work makes it a real pain to work on as I have to have it usable by Monday morning
Anyone know what it could be or have had the same issue and now know what it is
