tomsky wrote:Can anyone recommend where to get a good quality cover thats design for the Mk1 and fully waterproof as the car is kept on th drive.Now ive finally got the car dry seems the best idea until i cure
(says optimistically) the leaks.
tomsky wrote:thanks guys, happy to invest in something decent as cheaper than replacing all the bits that are rotting from the leaks! will check them out
thanks
Tom
cartledge_uk wrote:The problem is, if a car cover isn't breathable it will hold the moisture against the MR2 and rot it.![]()
plus all the wind will ship it about and rub the paintwork.
You need a breathable and fleace lined cover to keep the car protected.
For example:
http://www.hamiltonclassic.co.uk/acatal ... t.html#aMT
