[Mk2] [NA] No power to stereo
philmr2
Post by philmr2 »
I have no power to live feed on stereo plug, checked fuse and all is fine and dandy.
Could the problem be an issue with the amp not working properly, any ideas would be a great help.
mozzafan07
Re: [Mk2] [NA] No power to stereo
Post by mozzafan07 »
what type of set up is it your running?
I had to rewire all my speakers and connections due to the stereo wiring being cut into so many times before and the active system being bu88ered.
mozzafan07
have you got a good earth connection too?
mozzafan07
I have a rev2 UK n/a
from stereo --- from car
pink --- green silver dot
yellow --- white silver dot
black --- brown silver dot
red --- red silver dot
blue --- red and black stripe silver dot
that got it on and working for me, the rest are speakers and one is aerial, some are unused.
it depends on what your setting up, pls let me know if that helps,
good luck
philmr2
Post by philmr2 »
Hi cheers for all the info mine is an active system, at the moment trying to get it to work on a standard stereo, ive checked the main plug with a voltmeter and no power to it at all :(
mozzafan07
if its the main plug/loom from the car it could be a crappy wire further down thats decided to split.
did you disconnect everything and try the meter on the wires with the car turned on too?
try connecting the red silver dot wire
and the brown silver dot wire
via the meter
+ to red
- to brown
(your wires may be different)
philmr2
Post by philmr2 »
I will check the loom for any breaks, maybe get hold of another loom and try again
mozzafan07
good luck, keep me informed and I'll try and help as best I can.
eletrics can be a ball ache when things go wrong lol
Return to “Electrical”
