Fitting new wheel stud
xtremepix
Post by xtremepix »
Hey,
I snapped a wheel stud last week, and got my hands on a replacement. I tried to fit it yesturday by removing the brake caliper and sliding it behind the disk and into the hole it fits in, but there wasnt enough space for me to do this.
Could anyone explain how I get the stud into the hole it lives in?
Thanks!
Ren0W
Re: Fitting new wheel stud
Post by Ren0W »
It is just possible the way you did it?
No need to get everything off?
Just turn the hub into a position where one hole will be free.
Just tap the old one out, place new one it, and use an old bolt to pull it fully in.
That's how I replaced all my studs, I think :eye:
xtremepix
Post by xtremepix »
I'll give it another go then. It just seemed that the (excuse my non-technical terms!) metal cover-type piece behind the disk was in the way, so thought I may have to remove the entire hub assembly? I hope I can do it the easy way!!
Thanks for the quick reply =]
Peter Gidden
Post by Peter Gidden »
xtremepix wrote:I'll give it another go then. It just seemed that the (excuse my non-technical terms!) metal cover-type piece behind the disk was in the way, so thought I may have to remove the entire hub assembly? I hope I can do it the easy way!!
Turn the driveshaft flange so the hole where you want the stud to go is at approx. 3 o'clock. With disc off, should wiggle through without much difficulty.
riot68
Post by riot68 »
Peter Gidden - SBITS wrote:should wiggle through without much difficulty.
Says that to all the girls :wink:
Sorry couldn't resist...
visual anarchy since 1990...
riot68.com
