Problem solved:
Variable Injection control module.
Takes 0 to 5v dc input such as throttle position, MAF, MAP sensor.
One dial allows you to select the spray on point.
Another dial adjusts the injector flow relative to the sensor output.
This will reduce water/alcohol usage as well provide it at a rate to match your air and fuel intake needs.
This could also eliminate the need for a FMU such used on ATI,Vortech, etc kits.
If you are nearing the limit of your injectors or fuel supply, this may be the solution to your problem.
Ill try this little thing and se what happens!
