NEW member / owner having a bad time
mgregor
Post by mgregor »
Hi Guys,
I am a newbie to the MR2 world and recently purchased a 1996 REV 4 N/A, the car itself is very clean even though reading 99000 on the clock.
I love the feel and look of my new motor but have had a bad time reliability wise.
Bought the car for £600 with T&T, which at the time thought was too good to be true and after day 1 realised it was. starting issues from cold first morning and after ringing the bloke i got it off i found out he had fitted a switch under the dash to bypass the CTS.... not good!
changed the CTS sensor but still would not start from cold.
put up with it as i was just using it to get to work and back but averaging 23/Gallon was killing my wallet. :cry:
3 weeks later on my way home from work a strange noise?? next junction cut-out and struggled to start let alone idle, compression test showed 70/70/150/120, oh my what had i done?
head gasket blew through on the sealing ring from cyl 1 to 2... common?
have now spent 3 months stripping, saving, rebuilding and hope to be on the road again soon.
rebuild itself has not been too much ball ache but head was like a banana requiring 0.5mm off in order to get good clean-up :pale: will it run? only a turn of the key will tell.
So, needless to say my intro to the world of MR2's has been a rocky road but i will not give up.. even if it bankrupts me i will drive my pride and joy again...
once i have enough posts ill get some pics up but for now i'll just keep on believing that it will fire up when i've finished. :mrgreen:
StuRobinson88
Re: NEW member / owner having a bad time
Post by StuRobinson88 »
sorry to hear your mistfortunes. on the bright side - at least you only paid £600 for a rev 4! lol.
hope this rebuild sorts it out. i can not see why it won't be very reliable once sorted out. it just needed a little tlc...!
stu.
mgregor
Post by mgregor »
StuRobinson88 wrote:sorry to hear your mistfortunes. on the bright side - at least you only paid £600 for a rev 4! lol.
stu.
lol. yeah did get it cheap.... just a shame its sat on axle stands for longer than i got to drive it.. hopefully done for this weekend and i can enjoy the thrill of the 2 again.. :D
stu.
My centiments exactly. All the best with it mate, and welcome to IMOC :D
timlowthian
Post by timlowthian »
Good to see you havent given up!! You wont regret it when its all working again! :thumleft:
Rev 1 NA to Turbo conversion!
ashley
Post by ashley »
Keep at it buddy, that is a heavy head skim- 0.5mm :shock:
I've got a spare head you can have for not much if want...?
mgregor
Post by mgregor »
yeah i know, was told to try and avoid taking off more than 12 thou, i have skimmed 15 thou so dreading turning the key but thought as the rest of the lump has done 100k, compression wouldnt be at its upper limits anyway (i hope). Might need that head if s**t happens which it usualy does with me. How much would you be asking for it?got to try this 1 with al the money i have put into new hg, skim, lapping valves, new shims etc. Just fingers crossed i supose.
ashley
Post by ashley »
Yeah- definately worth trying if you've already slapped it all together!
If you need the head just give me a shout- we can work sommit out mate, it won't be expensive though :thumleft:
mgregor
Post by mgregor »
you guys are a friendly bunch. Im liking this forum already. Looked into buying a head from a car bein broken and got quoted £275 + vat. So just went ahead and skimmed it as i wasnt prepared to pay more than half of what the whole car cost. Lol. I did try and skim .3 but the fire face had not cleaned up at either end so needs must.
ashley
Post by ashley »
£275+VAT :shock: :shock: :shock:
Mate- you could get 2 REV4 na engines for that! Not surprised you went with the one you had... :eye:
I'll be keen to see what results a pressure test gives once you start up, you might even get a bit of extra power with such an aggressive skim :mrgreen:
mgregor
Post by mgregor »
would be nice! :D more likely to blow the rings off the pistons though i think, well compression has to be better than 70-70-150-120. some of my farts have more compression than cyl's 1 and 2 had :twisted:
StuRobinson88
mgregor wrote:me of my farts have more compression than cyl's 1 and 2 had :twisted:
\:D/ :clap: looooool
mgregor
PICS
Post by mgregor »
Ok, so 15 posts hit, now its time to see if i can upload some pics:
Here goes;
StuRobinson88
looks good. don't know what you're winging about!! lol.
mgregor
Post by mgregor »
StuRobinson88 wrote:looks good. don't know what you're winging about!! lol.
LOL.... this
Uploaded with ImageShack.us
StuRobinson88
5 minutes to pop the wheels back on and it'll be ready for a blast!! i literally cannot wait for these 2 months to go so i can drive my 3VZ!!
mgregor
Post by mgregor »
lol.. i wish. not far off but a few loose ends to tidy up first (connect)
why do you have to wait 2 months?
StuRobinson88
i'm busy busy busy in Afghan!!
Looks a lovely example there mate. Love azure blue 8)
mgregor
Post by mgregor »
:shock: ........ wow, how is it? not something i could do. greatest of respect to you.
