right after swapping over turbos im leaking on the feed pipe at the bottom of the turbo
, now i replaced this pipe 2 and new gasket on my old turbo
, fitted my new one and its still leaking wot am i doing wrong is there a certain way the small gasketg goes
, i have been using a smear of silcone over the gasket to hold it in place
, i tighten the 2 bolts as tight as possible
is it a common place to leak
is there anything else i can do
, a replacement pipe or something
