rear light clusters pre facelift / facelift interchangeable?
Anyone know if the rear pre facelift and facelift light clusters are interchangeable?
Re: rear light clusters pre facelift / facelift interchangeable?
Yes but your going to need more than just the light unit themselves as the panel that goes between them is a different shape and the boot lock is different etc. I'd estimate spending about £150 on parts 2nd hand. Good news is its an easy job to do. Have a look here on how its done :-)
http://mr2.noegruts.com/t-lights/install.htm
this is the mk3 section
DOH!!! Think I need to go back to bed LOL
They are interchangeable, however some have found when buying from eBay et al that the connectors are different or removed by the previous owner, so you may have to either cut your own connectors off to replace or buy new ones from Toyota.
Other than that it's a straight swap.
