a bit of history.
All speakers have been rewired with direct cabling to a new ISO plug in the dash.
The stereo works fine, everything else is working fine, all electrical items are doing as they should.
any ideas what it is and where?
ta
gavin
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works.Or something falls off, in which case you've hit it too hard.
Quigonjay wrote:have you tried turning the wheel when stationary to see if you can hear the clicking?
possibly the power steering relay located in the frunk
BLZ-8027 wrote:g.lewarne wrote:ok this is a strange one..
However, when im driving along, there is a relay somewhere clicking away about every 15 seconds.
I cant really hear it well enough to locate it, and most bizarrly it wont do it when im idling, ONLY when moving.
ta
gavin
Being as it doesn't do it when stationary,are you sure its an electrical
clicking noise
,or a loose part knocking?
theres a couple of relays behind the stereo,examples are
,1 for the key alarm and another for lights on reminder
,could have disturbed them and they are knocking around now?
Slarty wrote:It's not something silly like the actual speedometer/milometer that's clicking is it? Easy enough to check, just pull the clocks out and take it for a drive..
toxo wrote:Is your trip counter stuck? Happened to me and it clicks regularly as you suggest.
Slarty wrote:Ah I bloody said that too!Least you've found it though, good stuff
