I have a problem with my rev2 tubby, it does not want to idle at all! Basically it starts perfectly fine and runs at about 1200rpm for about 3-5seconds and then just dies, as if the fuel has been cut or something.
I have checked compression which was fine as expected seeming as it starts fine and runs well for aprox 3-5 secs.
I noticed that when i done a compression test all the spark plugs were cocked up so it seems as if it is running too rich.
I have checked for fault codes but i just get a steady flashing of the engine managment light so no codes in memory, i have tried resetting the ECU but still no joy.
This all started just after fitted a rev3 turbo and MLS headgasket along with a manual boost controller, which was set to 1bar.
I dont know if it could be related but before all this happend and before turbo was fitted, when the engine got nice and warm it would idle around 750rpm and fluctuate a little, almost like it was going to stall!
Im not sure what to check next so any ideas would be great.
Hopefully someone can offer advise
