On doing this all i get is a message saying major error contact sony technical
I have tried everything nothing works.
My new hard drive is 320g
](./images/smilies/eusa_wall.gif)
wickermonkey wrote:If i can remember from when i did mine if your not sliding to the side when your putting it back in then your not connecting it at all to the sata connectors.did you make a backup of you old hdd?
wickermonkey wrote:wickermonkey wrote:If i can remember from when i did mine if your not sliding to the side when your putting it back in then your not connecting it at all to the sata connectors.did you make a backup of you old hdd?
sorry just read the post again rather than skiming it.I take it you have a slim and not an original, is there any code that come with the error and does it still work if you put the old hdd back in?
tarmac terrorist wrote:wickermonkey wrote:wickermonkey wrote:If i can remember from when i did mine if your not sliding to the side when your putting it back in then your not connecting it at all to the sata connectors.did you make a backup of you old hdd?
cant remember what the code was but it starts 800 i think,yes as soon as i put the old hard drive back in it works fine
tarmac terrorist wrote:Ps I've tried requesting you as a friend on the ps3 herb about a year ago now lol
