Hi, the chassis number of the gears, that came of the car I removed the gears from was, SB164ABK10E084824 1.8 7AFE CARINA E
Is your car a 1A or a 1B mine was a 1B.
If you can get your Toyota dealer to search the chassis number
for the 5th gear numbers you should then have the right gears.
I hope this helps.
Bill.
