I want to change the front and rear brake pads myself.
I'll be using MR2 stock pads but if anyone can suggest any suitable alternative I'm all ears.
Any help would be greatly appreciated.
Regards
Paul
Ekona wrote:It's an absolute piece of cake, and if you're just changing pads it is staggeringly obvious which bolts to remove.Don't forget to replace the anti-squeal shims and with a healthy dose of copper grease too
Stock pads are just about the best you'll get your hands on and unless you're running 200+ bhp on track you'll never need better.![]()
excalibur1814 wrote:P.s.Someone said that the rear left brake hand brake cable goes under the fuel tank
excalibur1814 wrote:As soon as I read the line'fuel tank' I crumble like a Ginger biscuit.
