[Mk2] [NA] Morning Stalling
spencersanford
Post by spencersanford »
Hi guys, newbie here!
Just bought a 2.0 GT 1997.
Only issue with it is stalling in the morning.
If I start it up, it has an erratic idle, dipping up and down, if I rev it, it rises, then dies. I need to hold it at around 2k rpm for 30 seconds then it is fine.
Any ideas?
I think it needs a good service as it has been stood for some time, but didn't know if there is a common fault?
Any help appreciated, many thanks.
Baker
Re: [Mk2] [NA] Morning Stalling
Post by Baker »
could be lots of things.
Idle control valve need cleaning/replacing.
Air filter clogged.
fuel filter clogged.
coolant temp sensor (if an NA has one..not too sure)
Are the symptoms gone when its fully warm?
A good service is a must though.
my mates alfa has exactly the same thing, he hasnt serviced it in 5 years apart from 1 oil change! ](*,)
g.lewarne
Post by g.lewarne »
dirty / sticky / faulty ISCV most likely culprit
would align the TPS while your at it too :thumleft:
Slarty wrote:
it's just that we subscrible to the theory of hitting it harder until it works. Or something falls off, in which case you've hit it too hard.
spencersanford
Thanks for the suggestions!
Once warm it does not stall, however it does idle slightly high, between 1200-1400rpm.
Also now the clutch system develops an air leak :D
JeffD
Post by JeffD »
sounds like your iscv needs cleaning - have a look a this thread for pics
http://www.imoc.co.uk/forums/viewtopic. ... light=iscv
