I'm looking to stiffen up the car a bit so I thought I'd try fitting some braces.
Are there any custom ones kicking about?
Thanks!
Gianni
Retro_Boy_G wrote:Hey guys,
I'm looking to stiffen up the car a bit so I thought I'd try fitting some braces..
I can seem to find some OEM front ones on eBay for a reasonable price but I can't seem to find anything for the rear! I seen a Cusco one for sale but it said it was specifically for the SC models.
I've thought about trying to fabricate my own but there just doesn't seem to be much room to fit a bar to run across the engine bay without hitting something.
Thanks!
Gianni
Jim-SR wrote:Its just fabricated brackets that bolt to the strut towers(using the top mount nuts), and then a solid aluminium bar that runs across the bay and bolts to the brackets on either side.
Amazingly it doesn't foul on anything at all if my memory serves me correctly.
The only drawback I think is that you can't clip the engine lid prop back in to its normal place, I think I had a cable tie around the brace that I'd slide it into.
I asked God for a bike, but I know God doesn't work that way.So I stole a bike and asked for forgiveness.
Jaspa wrote:Jim-SR wrote:Its just fabricated brackets that bolt to the strut towers(using the top mount nuts), and then a solid aluminium bar that runs across the bay and bolts to the brackets on either side.
If it's similar to what Limey mentioned above, you also can't check your oil without removing the coolant expansion tank but that's not too bad in the great scheme of things.
Stuart
PW@Woodsport wrote:A bit"clonky" by todays standards, i might do a modern version sometime.
SuperRedMR2 wrote:Are they solid bar????
PW@Woodsport wrote:I maybe over did the bar a tad..
