Bob
jon wrote:There's 2 relevant signals between the engine ECU and the power steering ECU, they are PS& PSCT.
As far a I know neither of these signals exist on the ST205 ECU.
PSCT is an output from the engine ECU to turn on the power steering.![]()
The ECU turns on the power steering when the engine is running but not when the engine is starting
Disconnecting this signal from the engine ECU connector will apparently make the power steering run any time the ignition is on.
PS is an output from the power steering ECU to request that the engine ECU increases the idle speed to handle the extra electrical load caused by turning the steering.
