[Mk2] [NA] Spare key
smoke
Post by smoke »
Hi there,
I need your help... :wink:
I've only one key for my MR2. :oops:
Mine is a 1996 Rev 4 (one of the first ones, accordingly to the chassis number).
My key looks exactly like this one: www.carkeyhelp.co.uk/products/Toyota-MR ... 41RAT.html.
I've got a question:
I've got a led blinking red in the dashboard (labeled "SECURITY").
Thanks to that I think I got a chipped key.
May I have some confirmation?
Does the chipped version start with Rev 4?
Just to order the right one...
smoke
Re: [Mk2] [NA] Spare key
Post by smoke »
Panic if I loose my only way in... :shock:
smoke
Post by smoke »
No Rev 4 guys for me?
:cry:
smoke
Post by smoke »
Please, just have a look on your dashboard... :oops:
MR2Pagey
Post by MR2Pagey »
The REV 4's and some REV 3's have a Immobiliser and transponder. They are all linked to the ECU, etc and the key would be a nightmare to source and get coded.
toxo
Post by toxo »
Not a complete nightmare if it's a UK car, Toyota can do it.
smoke
Post by smoke »
MR2Pagey wrote:The REV 4's and some REV 3's have a Immobiliser and transponder. They are all linked to the ECU, etc and the key would be a nightmare to source and get coded.
Thanks.
And how can you tell?
Is the "SECURITY" led a good proof?
I've seen behind the stereo a box labelled TVSS II...
smoke
Post by smoke »
Toyota confirmed I have an immo key.
Moreover the OEM key is not so expensive: 30GBP.
So I 'll follow your advice: Toyota!
Racer7
Post by Racer7 »
smoke wrote:Toyota confirmed I have an immo key.
Was this just for the key or with transponder and programming?
If so - which one? !
smoke
Post by smoke »
Just a chipped key (and then 30' of work to programming).
But I'm still fighting...
:D
riot68
Post by riot68 »
Most keys can be reprogrammed yourself, just need to know the correct procedure, usually invloves ign on and off multiple times etc. I've done my wives Primera a fair few time...
visual anarchy since 1990...
riot68.com
smoke
Post by smoke »
:roll:
I've found two on ebay uk,
one (for mkIII) on a site of a spare key manufacturer,
two on http://www.mr2oc.co.uk/
If it is around 20euro I'll pay for it.
I've already spent a week end to get the key code... ](*,)
Return to “Electrical”
