[Mk2] [Turbo] standard fuel pressure please? (need to adjust my adjustable fpr)
Tyrant
Post by Tyrant »
hey all, got an adjustable fuel pressure regualtor, trying to see whats up with the car so want to set it back to standard pressure, mr2 mk2 turbo rev2
what should it be set to when the car is not running but ignition is in the on position? what should it then be at idle?
Cheers in advance
hoping someone knows quick :thumleft:
^Trickster^
Re: [Mk2] [Turbo] standard fuel pressure please? (need to adjust my adjustable fpr)
Post by ^Trickster^ »
38 psi im more than sure, they changed it to about 42psi on the rev 3 i think
Graeme
Tyrant
Post by Tyrant »
Thank you!! I thought it was 40psi but wanted to double check, your a star, cheers mate
