Paul, its an OB1 gearbox as fitted to current B8-chassis Audi's
(A4, A5).
The manual version is fitted to 2.0 Turbo and Turbo Diesel cars.
Because the output drive shaft runs in front of the clutch and flywheel, the shaft is removable from the diff and is retained on the passenger side by a plate with three bolts.
The shaft bearing on that side is also attached to the shaft.
There's very little info on the web as they are pretty new
(even 034 motorsport didn't have one yet), hence I ended up just buying one.
The reason I bought it was to find a way of avoiding cutting into the cabin firewall
/ front support
/ fuel tank in the mk2 whilst using an Audi V8.
Thats not going to happen with a V12, but every little helps!
If you need anymore info, I've got one ere'
