Next mod for my track MR2 is to take out the sunroof.
Question is, are there any pre-made items available
(fibreglass, alloy or steel) that are a direct fit, or will it be a case of getting a sheet of aluminium and making one up myself and riveting it on?.
If DIY, what thickness alu plate should I use?
Will 1mm be too thin?
What about 1.5mm, 2mm, 3mm, or thicker?
Anyone done this already?
If so, what did you use?
