Ryan
toxo wrote:Silly question I know but it's not the steering lock pressing on the ignition barrel is it? Wiggle the steering wheel and see if that has any effect.
foxy-stoat wrote:Key has properly worn as you say.![]()
A good time to buy one of them nice toyota gold keys off ebay.
Your local key cutting person can cut you a new key and should sort the problem.
foxy-stoat wrote:Naaaa, tell them its worn down and they can make the new one as it should be.![]()
Well thats what our local key cutter did for me, nice chap, only had 1 eye tho!
foxy-stoat wrote:Them key cutters are pretty good at what they do!
StevieL wrote:New barrel from your local friendly MR2 breaker, and your sorted brruuvvvaaa!
ryan wrote:I initially thought it was a frozen ignition loxck, but a boiling hot key and de icer hasnt worked, the only thing that seems to work is 10minutes of key wiggling before it starts! I can only assume the key has worn and isnt unlocking the ignition properly.Anybody have any other ideas?
Ryan
