I bought the car in march this year as a standard low mileage full black leather rev3 n/a for nearly
Spec
Rev3 turbo engine
Rev3 turbo lsd gearbox
Xs power s/s twin exit exhaust
Uprated intercooler
Magnecor leads
Air impulse 2 induction kit
Ohlins adjustable shocks
Trd lowering Springs
Cusco front and rear strut braces
Tein pillow ball front tension rods
walbro 255l/h fuel pump
16" staggered yokahama advan sa3 split rims
Exedy racing clutch and lightened flywheel only done about a 1000 miles
Thats the good bits now for the bad
since the conversion was done about a month ago their are a couple things tha still need sorting which i havent got time to sort out
The speedo does not work
The low oil warning light is on
the abs light is on
the rear fog light warning light comes on the dash when you brake
the front tyres need changing as they are a bit perished
one of the front wheels has some of the nuts and botls missing front the split rims
the tracking also needs doing as the sterring wheel is at an angle but it does not pull to the left or right
the car had a light front end crash in 2007 which is on the log book and says it has had an identitiy check.
Email me or phone me on 07528551142
it is also on ebay
im after
