chipped glovebox... paint colour?
joncus
Post by joncus »
Anyone else got a scratched glove box? making the inside for my 2 look pap, what paint do i need to fill the chips in with? has anyone done this before?
cheers, Jon
JohnnyC
Re: chipped glovebox... paint colour?
Post by JohnnyC »
Exactly the same problem here :cry:
I was thinking of getting a new/used one as I'd hate to paint it and find out that the colour didn't 'quite' match :shock:
Someone must know of a paint for a good match :whistle:
Dale_V
Post by Dale_V »
I did this with mine! the paint peeled leaving the grey.
I bought some black Foilatec interior spray from Halfys, it costs about £20 but is awsome, just looks brand new and is a perfect colour match
sadga
Post by sadga »
Dale - is that exactly what its called, Foilatec? Cant see it on the Halford Website and i could do with some for my glovebox!!
Cheers..
Dale_V
Post by Dale_V »
sadga wrote:Dale - is that exactly what its called, Foilatec? Cant see it on the Halford Website and i could do with some for my glovebox!!
Cheers..
its Foliatec "carstyling Interior colour spray" and you want the "flat black" version not "gloss" I believe. The barcode is: 4002581200219 ;)
It cost around £20 as i remember, but has done a great job!. Just to remind you, make the surface clean first from grease, I reccomend Halfords surface cleaner... about £3
JohnnyC
Post by JohnnyC »
Did you have to sand away all the original paint off? Any need for primer too like what people use for their centre console bit?
Dale_V
Post by Dale_V »
JohnnyC wrote:Did you have to sand away all the original paint off? Any need for primer too like what people use for their centre console bit?
no dont sand the paint, you will lose the texture! I never primed mine and 1 year on its still looking like new. :D as long as the surface is clean it doesnt matter.
Oh and this stuff stinks! so make sure you can leave the windows open long enough if your spraying in situ...
JohnnyC
Post by JohnnyC »
Cheers Dale :thumleft:
Dale_V wrote:so make sure you can leave the windows open long enough if your spraying in situ...
Not advisable round where I live #-o :mrgreen:
Dale_V
Post by Dale_V »
JohnnyC wrote:Cheers Dale :thumleft:
no problem
LOL like that is it #-o
sadga
Post by sadga »
yep, cheers Dale, I'll give it a go..
joncus
Post by joncus »
cool, thanks for that havent checked forum for a few days! ill definatley try it, see if i can get some before and after pictures for everyone
JohnnyC
Post by JohnnyC »
I eventually got round to getting this paint - superb colour match.
But, the paint is coming away again, in exactly the same place.
I didn't put any laquer, thinking about putting some, would this make it too shiney?
ToyotaTosh
Post by ToyotaTosh »
another job for the weekend :thumleft:
alan7
Post by alan7 »
JohnnyC wrote:I eventually got round to getting this paint - superb colour match.
laquering will give a gloss finish mate
try stripping it back with some thinners but be carefull then use panel wipe before re applying it :)
JohnnyC
Post by JohnnyC »
Cheers, I re-did it 5 years ago :mrgreen:
And it still looks good :thumleft:
ToyotaTosh
do you have any pics Johnny?
JohnnyC
Post by JohnnyC »
Here:
Let me explain the pic first. You probably notice the glovebox doesn't look the same colour as the top of the dash - this isn't noticeable to the eye that I've noticed.
AND, the part to the left of the glovebox was NOT painted, that part is the original colour - so you can see how well the main part of the glovebox matches :thumleft:
Dale_V
Post by Dale_V »
just to update, 5 years on... my glove box is still in great condition, and the paint match to the eye is spot on! 8)
Delgado-Go!
Post by Delgado-Go! »
Dale_V wrote:just to update, 5 years on... my glove box is still in great condition, and the paint match to the eye is spot on! 8)
did you spray the inside and does it look as good as outside?
mine has all peeled where the previous owner(s) have kept the service book and it has rubbed against the back.
will be off to pick this up this weekend if i can find out the way to get my rev5 dash/gearbox/handbrake area colour back to factory a finish.
Dale_V
Post by Dale_V »
I didnt spray the inside as mine was fine.... but im sure it will work fine if you clean it out well.. the key to the paint holding is using a surface cleaner to get all the grease off first
