engine temp low???
JDM-MAT
engine temp low???
Post by JDM-MAT »
my water temp gage is at the bottom and heaters are blowing cool air??? any ideas?
im thinking thermostat is this easy to change on the sw20-3sge?
thanks, mathew :-k
fishy89
Re: engine temp low???
Post by fishy89 »
id agree with thermo mate :thumleft:
JDM-MAT
Post by JDM-MAT »
is it easy to change on the mr2? iv never done this befor
fishy89
Post by fishy89 »
not changed one on an mr2, cant forsee it being hard, itl just be sitting inside the thrmo housing, il have a look at lunch and let you know where its located.
sorry cant say more, only had mine a week or so :)
JDM-MAT
Post by JDM-MAT »
thanks, i like to be hands on with my cars.
dazzz
Post by dazzz »
Check your system hasn't any airlocks around the heater matrix first.
Also check your coolant system is full and not leaking and also that the water pump is pumping
fishy89
Post by fishy89 »
dazzz wrote:Check your system hasn't any airlocks around the heater matrix first.
surely if it has an air lock or the pump has failed youll find it'l be over heating ridiculously, coolant temp wise, which indirectly effects the heater temp..
on the n/a thermo housing is located just below the tb.
it was raining so could check properly but they are normaly attached via 3 or so 10mm nuts, pop the old thermo out, and re affix.
fishy89
Post by fishy89 »
**edit**
JDM-MAT
Post by JDM-MAT »
thank you very much mate :) ow just a quick one wats the tb :-k lol
JDM-MAT
Post by JDM-MAT »
how do i do this?
frogger
Post by frogger »
Look up how to bleed an MR2 and all will be revealed (regarding checking up on air locks).
You will need to know the bleeding process for when you replace the thermostat anyway.
If you know there's no leaks and the system is still full, you wont have an airlock either really, so continue with the thermostat replacement, which is the most likely culprit anyway really.
... And a tb is a throttle body...
How long you had the car? Watch the temp gauge carefully after replacement if this is the first properly cold day since you bought the car (i.e. thinking along the lines of has previous owner removed thermostat or forced it open to hide a overheating problem).
JDM-MAT
Post by JDM-MAT »
iv had the car about 2month, the temp gage iv found out tonight moves up slow to the middle. its only just started doing it. ahhh bleeding :( this could cause me a problem lol. not sure how easy it is on a mr2
Ste2
Post by Ste2 »
JDM-MAT wrote:iv had the car about 2month, the temp gage iv found out tonight moves up slow to the middle. its only just started doing it. ahhh bleeding :( this could cause me a problem lol. not sure how easy it is on a mr2
that is what is should do! search google/imoc/mr2oc for radiator change. all the ins and outs of bleeding is the same apart from replacing the rad :thumleft:
oh and
http://www.lovehorsepower.com/MR2_Docs/ ... system.htm
google is your friend.
toxo
Post by toxo »
And for the record, the thermostat housing's nowhere near the throttlebody. It's on the corner of the block nearest the driver's side air intake, where the aircon pump / intercooler are.
The MR2 has a complex cooling system (probably 20 metres more coolant pipe than most cars) and plenty of places for air to get trapped. The bleeding procedure is also complex and has to be followed properly. The long and short of it is, on most cars the bleed point on the radiator is high, on the MR2 it isn't so you can't *just* use gravity to bleed air out.
Also airlocks only tend to show when stationary in traffic, the cooling system is good at cooling due to the volume of coolant (13L or so) so it's only when the car gets really hot that overheating strikes.
JDM-MAT
Post by JDM-MAT »
the car is not over heating, and for the time it takes the car temp gage to move to the middle i have traveled 12 miles.
toxo
Post by toxo »
Bleed it.
JDM-MAT
Post by JDM-MAT »
toxo wrote:Bleed it.
ahhh S**T, lol thats a mission. thanks for all your help i will try to Bleed it.
toxo
Post by toxo »
No it's not! It's just different to other cars. You just need 2 bits of 5mm hose. Do this, except just top it up rather than filling. Make sure you use the same type of coolant that's in there already - don't mix different types of coolant.
dazzz
Post by dazzz »
It's easy mate. it just looks a big job.
Basically you open the front bleed point with tube attached if it's the stock rad. Open the heater matrix bleed point with tube attached. open the rad cap and watch what happens.
Because the front and rear are both open to atmosphere this should let any air escape.
Keep pouring in coolant untill the tube coming from the rad starts to fill with fluid. the fluid should only rise to the same height as the rad cap in the engine bay. Let it settle for a few mins then see if you need anymore.
I do mine with the rear of the car higher than the front so to make the pipes underneath not horizontal, easier to get air out in my opinion but probably makes no real difference.
JDM-MAT
Post by JDM-MAT »
wow after reading im more confident :) thanks guys
