MR2 GTS Turbo (rev2) Huge spec!
pusherman25
Post by pusherman25 »
Hi, the time has come to sell my MR2 Turbo. I've owned the car for just under 2 years and thoroughly enjoyed owning it.
The car has had extensive work carried out to update the engine and chassis.
I just had the car rolling road tested at power station in Tewksbury and it made 258BHP and 278ft/lbs of torque. This was at 1 bar of boost. This is a very respectable power output and thanks to the strong torque produced the car is brilliant to drive on the road and track.
http://www.facebook.com/video/video.php ... =727472400
(this is a link to the video of the car on the nurburgring - its from facebook so not sure if it will work but give it a go. if it doesn't and you want to see it drop me an message with your email address and i'll send it over)
This is the spec list;
Rev 2 GTS Turbo
CT26 turbo with forge actuator
TRD 1.4mm head gasket
Reworked cylinder head
HKS 264 cams
HKS adjustable cam pullys
Greddy cambelt
Blitz Access ECU
Blitz BOV
Fidanza lightweight flywheel
Exedy clutch
Uprated TRD LSD
HKS Hiper exhaust system
3" Downpipe
Apexi intake
New hardpipes
Samco coolant pipes
Greddy side mount intercooler
Rouge twin extractor fans
Aftermarket oil cooler + remote filter
Blitz dual SBC boost controller
Apexi turbo timer
TRD shocks and springs
Fully polybushed suspension
Tarox front and back discs
EBC redstuff pads
Blitz boost gauge
Cusco front strut brace
TRD rear strut brace
Black 3point harnesses
Lightweight Enkei Split rim alloys
Sony CD/MP3/WMA/USB/AUX player
VAG gauges (oil temp/oil pressure/volts)
Blitz boost gauge (mounted on the centre of the steering column)
As you can see the car has been heavily upgraded, but is a good base if your hunting more power. I found the car brilliant at this power level, just the right amount, but a turbo, manifold and fuelling upgrade could see well in excess of 300+bhp.
The car has recently just had a full service including new distributor (rotor arm and dizzy cap) and new water temp sender. Its also just had a full laser alignment session and fast road suspension setup.
The car has been fully serviced at Hyeline Automotive in Newport. They also carried out the engine and chassis upgrades. I have receipts to back up all of the service history.
As you can see the car has had a great deal of money spent on it. I made the trip to the Nurburgring in may 2010 and put the car through its paces. It performed faultlessly, completing 10 laps of the track without a worry.
The MR2 is in brilliant condition and the enkei alloys really compliment the look of the car. The bodywork is in brilliant condition with only a few stone chips that would give away the 20years its been on the road.
It really is a very capable car, bags of torque and power, good looks, comfortable interior, brilliant MPG, on the way to the ring I got 390miles to the tank.
I am only selling this as I'm just about to start university and need to raise some money to fund myself.
£3850 OVNO
I think thats everything you need to know about the car. Extra photos are available. Please contact me if you have any questions.
Your welcome to come and view the car and test drive with sufficient insurance cover.
Tom
