So, bought off here second hand:
Janspeed downpipe and mongoose exhaust
Bought new from Fensport: shiny electronics, speed limit remover and fuel cut defencer.
I just said to Rogue, put it all together and up the boost to something safe.
Matt kept me updated all of the time, they were scratching their heads at one point as it just wasn't running the right boost and check engine light kept coming on.
Matt said it felt like an ignition system problem, Ha! I thought well everything is new.
Well now having got the car back, driven it sensibly(ish) on the run home I have now taken it out for a warp 7 blast about.
What a transformation, it now feels like a sports car should.
The exhaust also drowns out the silly engine noise which I've never been a fan off.
The engine feels very smooth and revs cleanly to the limit.
Even better is you can change up early through the gears and it has power everywhere in the range.
I think I may have set someone's car alarm off at one point also
Once again, thanks to Matt and Rogue for doing a quality job.
Adam
