Should a Tom's underbody brace have a bend in it?
bluesmoke
Post by bluesmoke »
Just wondering as I've bought one and it's just turned up and is slightly bent in the middle. I had thought that they were like a straight bar rather than having any curvature.
NDR008
Re: Should a Tom's underbody brace have a bend in it?
Post by NDR008 »
I had bent my mk1's by jacking it incorrectly (and no - I did not jack it from the middle), but that was the Mk1's factor brace across the 2 arm pivot points.
bluesmoke
Post by bluesmoke »
I'm pretty sure it should be totally straight and I've been sent a damaged one :(
CardHore
Post by CardHore »
hi matey... congrats on getting one of these, handling ability is just untold after fitting mine! However u are correct, it should be straight without any curves. chances are it came from an accident damaged car. still should be ok though, not sure if it will fit though, is it more of a kink or actual bend?
SFLee
Post by SFLee »
i brought one recenty from 3s, i can upload the picture if you want
bluesmoke
Post by bluesmoke »
More of a kink really I guess. I don't want to send it back and get a refund because they're so rare and I had to source it from Germany, but I also don't want either a weakened item which doesn't do what I bought it for or to damage it by trying to straighten it.
jdbecks
Post by jdbecks »
you will weaken the metal by straightening it..same if you heat it up
bluesmoke
Post by bluesmoke »
So I should seek a refund then and try to source another? Can't see how it will fit without being straightened :(
SFLee
Post by SFLee »
:ttiwwp:
let see how bend then
bluesmoke
Post by bluesmoke »
Will get a photo up in about 45 mins
bri0905
Post by bri0905 »
I'd take it to a fabricator, get a copy made and send it back for a refund!
96 Rev 3 Turbo, Done!
NDR008
Post by NDR008 »
jdbecks wrote:you will weaken the metal by straightening it..same if you heat it up
Actually if he bends it, it will only get harder.
Metals work harden. You substitute ductility for hardness, and thus reducing toughness, but I doubt it is THAT bent to make that much of a noticeable difference.
bluesmoke
Post by bluesmoke »
OK here we go guys:
bluesmoke
Post by bluesmoke »
Come on guys, waiting for your words of wisdom here! :D
NDR008
Post by NDR008 »
Bloody hell, I thought it was worse. I know how I would bend it back, but doubt you have the equipment I am thinking of.
bluesmoke
Post by bluesmoke »
NDR008 wrote:Bloody hell, I thought it was worse. I know how I would bend it back, but doubt you have the equipment I am thinking of.
A pipe bender?
I am currently thinking a rubber mallet and hitting it very hard lol. I am aware this may not work though..... :?
jimGTS
Post by jimGTS »
Drive over the middle of it?
bluesmoke
Post by bluesmoke »
jimGTS wrote:Drive over the middle of it?
:lol:
Mr2_BadBoi
Post by Mr2_BadBoi »
bench vice and hammer job succesfully achieved :D will be straight in minutes :thumleft:
bluesmoke
Post by bluesmoke »
I don't have the facilities mate :lol: :lol:
