Unless you can find the offsets of the wheels we can't answer whether they'll rub or not.
and nor can any tyre dealers.
What I can tell you is you either want a 215 front with 235 or 245 rears or a 225 front with either a 245 or 255 rear.
It's the stagger that is most important.
either a 20mm or 30mm difference
(depending on handling preference).
Obviously the 225 front option with the corresponding wider rears means you're more likely to get rubbing somewhere but as said it's impossible to say for sure unless you can get the offsets.
If you go for a 20mm difference get the same profile front and rear.
If it's a 30mm difference you ideally want a 5% higher profile on the fronts.
