Boost only at 3/4 until 4-5000rpm is this normal.
N9THX
Post by N9THX »
After removing my manual boost valve i've noticed the boost gauge only reaches 3/4 until 4-5000rpm then creeps to full by about 7000rpm.
I read that the TVIS system may have been disabled, how can i check this?
While i'm on the subject how much boost could i safely run on my Rev3 turbo with decat,xs power manifold, big twin stainless exhaust, apexi induction and hks sequential bov?
I've ordered a boost gauge so i can measure what boost is running whereas before it was all a mystery. :?:
jdbecks
Re: Boost only at 3/4 until 4-5000rpm is this normal.
Post by jdbecks »
N9THX
Post by N9THX »
eh?
surely this is a good idea before any boost changes?
jdbecks
Post by jdbecks »
n9thx wrote:eh?
sorry, I miss read the first few lines, and thought you had adjusted the boost before having a boost gauge, the stock boost gauge totaly in accurate. everything will most likely be alright. once you can see on the aftermarket gauge
N9THX
Post by N9THX »
No mate, the car came with a manual boost adjuster but with stock boost gauge. The previous owner had split the hose coming from the turbo to the IC and i did the same a few days ago.
So i've removed the manual boost adjuster until i've got an accurate gauge fitted.
Not sure why there's a CT26 turbo fitted though, could it be a hybrid?
jdbecks
Post by jdbecks »
n9thx wrote:No mate, the car came with a manual boost adjuster but with stock boost gauge. The previous owner had split the hose coming from the turbo to the IC and i did the same a few days ago.
The Rev1,2 turbos say CT26 the rev3+ should say toyota. If you are back to stock and having boosting issues, you could check the tvis, it is under the inlet manifold and has a blue plug that should be connected, or the vacuum pipes near the actuator
jimGTS
Post by jimGTS »
dont confuse tvis with tvsv.....
you should be looking at the tvsv if your concerned with boost
:eye:
jdbecks
Post by jdbecks »
jimGTS wrote:dont confuse tvis with tvsv.....
:eye:
O yeah...its early :clown:
N9THX
Post by N9THX »
The TVSV connected after having a look.
Is this a 100% got to be disconnected and blanked off when running a manual boost adjuster?
