At WMS Brakes we've been doing motorsport
/ trackday brake kits for various cars for years but in particular the AW11 MR2
- but we've finally launched the two SW20 Mk2 MR2 kits.
There are two versions, 4P018 with 298.5x18mm discs and 4P065 with heavier 296x28mm discs
- each kit uses the same caliper and bracket
(one side of the bracket suits each kit) so it's possible to buy one and change to the other with minimal cost later on.
4P018:
The kits work with the standard OEM spec master cylinder as it has 92.7% of the piston area of the OEM caliper, and goes under most 16's and maybe the odd motorsport 15" but sadly not the OEM 15" wheel.
I've generated PDF files showing the profiles of both versions, the idea is you can print them, check they are 1:1 scale, stick them to card and cut them out
- and offer them up to the inside of your wheels to see if they'll fit!
298.5x18 4P018:
www.keri.co.uk/wms/4P018-SW20-298_5mm-T20-rotated.pdf
296x28 4P065:
www.keri.co.uk/wms/4P065-SW20-296mm-T20-rotated.pdf
NOTE: The recomended spec for piston choice is to fit the Rev2> larger rear brakes with this kit, more setup options will be added soon.
Specs are:
- 6061 T6 Aluminium WMS T20 calipers, CNC machined from billet and hard anodised, stainless pistons 1.38"/1.38" pistons
(optional 1.25"/1.25" pistons).
- 6061 T6 clear anodised brackets, with VERY strong 304 stainless steel threaded inserts
(this system is strong enough that we found during testing that an M10 grade 12.9 bolt will actually stretch before the inset fails!).
- Grade 12.9 cap head bolts
- We offer a 12-month NO QUIBBLE guarantee on the piston seals
(like most other race ones WMS calipers don't have external seals as they would burn off under competition conditions), if they fail we'll send you new ones even if you've been using them on a tractor.
This is to counter the worries people have about piston seals on race calipers.
.we have only ever needed to supply one or two sets and they were not due to dust getting in
- in fact we rarely or never sell any seals to even very old kits, and that includes rally cars
(mud/grit everywhere).
Bottom line is, keep the calipers clean like you would any other part of the car and there won't be any issues, it's just scaremongering.
4P018:
4P018:
4P018:
4P018:
4P018:
Rev 2 front brakes as a comparison:
Prices as of March 2014
4P018-S 298.5x18 kit
(calipers/discs/brackets/inserts/bolts) is
£495.00+vat
4P065 296x28 kit
£515.00+vat
Earls braided lines to fit
(Toyota ones don't)
£49.00+vat/pr
Upgrade to grooved discs
(not available for 18mm thick disc)
£40+vat
Pads:
- EBC Reds/Yellows are
£POA+vat/set
- Ferodo DS2500
(fast road)
£62.00+vat/set
- Ferodo DS3000
(race)
£63.00+vat/set
We are offering a discount structure, 2.5% off the for members, 5% off for Premuim Members which now applies to ALL PARTS.
Also any orders settled up by bank transfer
(optional of course!) has FREE SHIPPING otherwise it's
£10.00+vat
(to UK zone one only).
We also offer some handy EBC pads:
SW20 front Redstuff
£POA
SW20 front Yellowstuff
£POA
SW20 rear Redstuff
£POA
SW20 rear Yellowstuff
£POA
Fire away with any questions.
.here are photos of the lines:
------ NEW KITS IN DEVELOPMENT
We're looking at kits to use the 324mm Supra discs as used in some BBK big disc kits.
Here are some sneak peeks:
T20-S caliper kit
(4P088):
