Ok now this is getting really silly.
.we have bled this thing now so much there must have been at least 6 or 7 ltrs of liquid through it.but still no joy.
As soon as you touch the master cylinder the slave starts to move,and its very progressive but its like the master cylinder is either to small or the slave is to big and the clutch arm is just not being pushed enough in.
(we have tryed pressurizing the system,we tryed sucking it through with a propper suction bleeder and bleeding at different points)
We have taken the car now to a full time mechanic and he says it seems to be bled properly
(only liquid comes out no matter where you open a joint or valve.Its just not disengauging the clutch enough.
the car has new master and slave cylinders as well as a new
"clutch masters" clutch
(do these require a different slave cylinders??)
if you push the arm out and lodge it out with a spacer pull the pedal back up and then push it again it seems to be
perfect disengauging the clutch perfectly.
does any 1 know how much the slave cylinder comes out in mm
(moves the arm???)
at this rate it looks like i might have to modify the slave with a sleeve and a new custom piston.
