I have just done an engine swap on my rev 1 turbo
Firstly, on start up, the starter motor is staying engaged for a few seconds after the engine has fired, causing it to stall again.
Secondly, the car will not let me have boost!, it will boost but then hits a sort of fuel cut, but not the toyota normal one of just stopping boost.
I have a feeling the boost issue may be due to the SSQV fitted, the seals may have perished or something, does this sound plausable?
Also with the starter motor, could it be that the motor is shorting itself on, and why would it do this?
Any help you lot can give will be greatly appreciated!
Cheerss
